- Oct 18, 2001
Malice Clips!
http://www.maxpedition.com/store/pc/viewPrd.asp?idcategory=15&idproduct=351
I will still be offering the IWB TekLoks:
But I will start stocking a bunch of the Small Malice Clips from now on - available for any kydex sheath.
Here's an example of how to set one up:
First thing is to enlarge the hole you want use with a 7/32" drill bit. (1/4" can be used, but 7/32" will be a tighter fit)
Then just transfer the hardware from your TekLok to the Malice clip like this:
Flip side:
The rubber washer goes between the Malice clip and the sheath
flip it back over and tuck the end through the "buckle". Adjust according to your belt width (there are two tabs - on this one I pushed it through to the 2nd tab).
Loop your belt through it and you're set!
As you can see...you can adjust the angle of the sheath from horizontal (totally concealed behind the belt)....
...to completely vertical for a more traditional carry
The Malice Clip is great for those who feel a Teklok may be too thick for IWB carry. Both work great for me.
And, here's a pic of the knife - a K5 Karda in D2... 0.25" thick monster with a full flat grind.
Thanks for looking!
Daniel Koster
Flip side:
Thanks for looking!
Daniel Koster
