- Oct 18, 2001
Here we go!
A quick review of options:
Bushcraft
Specs:
7.5" overall
3" blade, CPM 3V steel, 1/8" thick, four 1/4" holes, scandi grind
4.5" handle
Option 1 = Blade blank only (heat-treat, bevels ground, 1/8" thick steel) = $50
Option 2 = Blade blank, 3/4"-1" thick block of exotic hardwood (TBD), 2 brass lanyard tubes = $65
Option 3 = Blade blank, 2 canvas micarta handle scales 1/4" thick profiled and pre-drilled for pins, 1 corby pin, 1 lanyard tube
= $75
Nessmuk
7.5" overall
3.5" blade, scandi grind, A2 steel
4" handle, two holes (1/4" and 3/8")
Option 1 = blade blank only = $50
Option 2 = blade blank, wood handle block, 2 lanyard tubes (1/4" and 3/8") = $65
Option 3 = blade blank, 2 micarta handle slabs 1/4" thick profiled pre-drilled, 1 corby pin, 1 lanyard tube 3/8" = $75
Make sure to specify which option you want!
Bushcraft
Option 1
Nessmuk
Option 1
***LIST CLOSED***
***LIST CLOSED***
***LIST CLOSED***
$30 deposit required (regardless which option you choose...$31 via Paypal)
Payment info here: www.kosterknives.com/payments.htm
IMPORTANT - I must have your first name, last initial before I sign you up on the list. :thumbup:
Thanks!
Dan
p.s. here is the link for the template drawing: www.kosterknives.com/KosterKnivesKitHandle.pdf
Bushcraft
Specs:
7.5" overall
4.5" handle
= $75
Nessmuk
7.5" overall
Bushcraft
Option 1
- teacher (Chuck P)
- teacher (Chuck P)
- tychoseven (Brian P)
- jlkitch (Jim K)
- madborderman07 (Jesse C)
- DutchV (David V)
- Soulrack223 (Carlos B)
- 007 Agent ZZero
- mckrob (Rob M) - waiting
- KBT (Kevin T)
- KBT (Kevin T)
- dr5trange (Mike S)
- dczippo (Doug C)
- dczippo (Doug C)
- dczippo (Doug C)
- Stephen90 (Stephen R)
- CUTS LIKE A KRIS (Kris J)
- pafka (Pavel Z)
- valcas1 (Paul V)
- valcas1 (Paul V)
- CWL (Charles L)
- Jeff H
- rayban (Rick G)
- Steve Lawrence
- wcy (William Y)
- sketchbag (Ankar S)
- Magnum22 (?)
- DJJ (Dennis ?)
- Tohatchi NM (Erik D)
- rickppoole (Rick P) - PIF
- abiggs
- Jeepnut22 (Phil A)
- teacher (Chuck P) - Black
- LordOnlyKnows (Jason F)
- mapper66 (Tim R)
- mapper66 (Tim R)
- Knife_Geek (Reed M) - Black
- usiel (Cameron L) - Green
- husk545 (Levi H)
- ombrapelone (Emanuele P)
- Boggs (Jim M)
- hutch762mg (Daniel G)
- hillst1 (Steve H) - Black
- welton (Steve W)
- inthe602 (?)
- messer454 (?)
- guitardemon (John H)
Nessmuk
Option 1
***LIST CLOSED***
- teacher (Chuck P)
- teacher (Chuck P)
- DutchV (David V)
- raythebigfoot (Ray F)
- El Chupacabra (Ryan H)
- KBT (Kevin T)
- KBT (Kevin T)
- dczippo (Doug C)
- dczippo (Doug C)
- dczippo (Doug C)
- CWL (Charles L)
- monarh99 (Corrie B)
- marekz (Mark S)
- Moff8 (?)
***LIST CLOSED***
- Suveges (Csaba S)
- pafka (Pavel Z)
***LIST CLOSED***
- mapper66 (Tim R)
- husk545 (Levi H)
- d_filgate (Dave F)
- dnm (David M) - Natural
- Rebelder (Rick N)
Thanks!
Dan
