- Apr 1, 2010
I recently picked up a couple of early 119s on that famous auction site. The first and the topic of this thread is a 119 barrel nut, and the other is a single line stamp 119. A little bit of history for those who don't know about the time lines of these knives. The 119 barrel nut dates between 1961 through 1963. The 119 one line stamp over laps the barrel nut, with dates of 1961 through 1966 to early 67, when the blade stamp BUCK* came into play. Typically the Barrel nut had a hand forged blade and a bolt was brazed to the tang. The handle was constructed and a "barrel Nut" was tightened down to hold the handle together. A plug of alumnium was fitted to the hole in the pommel to seal the barrel nut.
Fast forward to now. I watched this 119 barrel nut on the bay and it appeared strange. The pommel was crooked and it looked like there was a groove in the the plug. I figured someone thought that was the way to remove the pommel or something along those lines. I bid anyway and won. When I got it home I looked at this groove and it didn't have any tooling around the hole in the pommel. You would figure if someone used a dremmel or some other type of tool to cut this groove it would have left sign showing that type of work was done. I ventured a bit farther and used a flat headed screwdriver and attempted to turn the plug. Much to my surprise it turned and the handle began to loosen. I took this plug out and it was threaded and fit on to the bolt that was brazed onto the tang.
I have never seen this before and I'm not sure what to make of it all. In addition this 119 barrel nut is considerably heavier and has a real thick blade. I measured the blade and compaired it to the one liners I have. The 119 barrel nut has a blade thickness of .24 inches as compaired to the one liner 119s I have and they measured .13 inches.
Is it possible that this knife was some sort of early prototype or transition into the barrel nut era...??? If any of the x-perts have any ideas I love to hear them. Here are some pictures to help get an idea of what I'm talking about...
This first picture is just a few of my 119 starting with the barrel nut at the bottom working your way up to the 1973 three line stamp with 4 micarta spacers ( read with the blade pointed up)
Uploaded with ImageShack.us
This picture shows the barrel nut pommel with the grooved plug, I don't know what to make of it, HELP...
This picture shows the difference in thickness in the blades from the barrel nut to the one line stamp... sorry for the great picture of the clay I used to hold the knives side by side...
As you can see the barrel nut is almost twice as thick as the one line stamp. If they over lap in time should the difference in thickness be this dramitic.???
