Para Tip Up / Deep carry
Steve,
Thanks for the great work. My Para is a lot nicer now with the tip up / deep carry.
Thanks my friend. Glad you are pleased.
Enjoy.
STR
I've been thinking about buying a low riding clip and I got 2 questions.
1. what colors can you do besides blue jean blue, khaki, and bead blasted.
2. would I have to send you my para-military or could you do one off pics, ( Im a little afraid my pocket might get lonely for that week ;) )
I don't have a Para any longer so I'd need the knife to do it. To do it as pictured I'd for sure need it because it has to be drilled and threaded to mount the clip. If I happened to have someone's Para here at the time I could use it to make two clips to mount to the existing hole pattern in the knife but that is the only way I can think of that you could get one made to fit without sending me your folder. For what its worth my turn around time is pretty fast on smaller jobs just for that reason that I don't like keeping someones EDC that long.
I can get light khaki, darker khaki, brown, purple/violet, blue in a darker blue I call the blue jean blue and a more sky blue color with a bit more volts, blue green, green, gold, and mauve using the solution I use. Blue and khaki are the most frequently requested colors. I figure its because they blend with slacks at work pretty well.
STR
:D Thanks for the quick response, I will more than likely buy one soon. My only problem is i suck at saving money, as soon as i get 20 bucks i'll more than likely run to wal-mart and blow it on some dvd.
Yeah, I understand the money. I highly recommend saving since my solution had been 'deficit spending' until later in life when I finally got my head on straight around 40 years old. Looking back now I'm glad I caught on early enough but if I'd have been smarter I'd have done it about 20 years sooner than 40.;)
STR
See my low rider clip thread which is a sticky top the page always somewhere in the top six threads page one of my forum here.
It has all the info and the work order form I ask folks to fill out print and mail with any requests.
Thanks
STR
