The Buck 184 "Buckmaster" is a large Bowie-bladed survival knife, developed at the request of the US Navy SEALs. It was also featured in the movie Sin City by Frank Miller in 2005.
The knife has a blade that is approximately 7.5" (19cm) long, and is of the classic Bowie shape. The hollow-ground main edge is about 6.5" (16.5cm) long. The false edge is serrated on one side. The back of the blade features a very aggressive 3" (7.5cm) long sawback. Maximum blade width is about 1.5" (3.7cm), and the blade is .288 - .290-inch thick. The blade is forged 425mod steel. The handguard is about 6mm thick, with both ends curving slightly towards the blade. Each end is drilled and tapped for a 2" (51mm) long, 10mm diameter "point" which is designed to allow the knife to be used as an anchor when a line is attached to the lanyard ring at the pommel. The grip is 4" (102mm) long and 1.25" (2.8cm) in diameter, knurled and grooved for a sure grip. The grip is hollow, with a usable internal opening secured by the threaded pommel, which in turn is knurled, slightly larger in diameter than the grip, and sealed with a black rubber O-ring. The threaded pommel also secured a 4.5mm thick steel stamping which is pierced to provide a lanyard/rope hole.
Regarding the grappling hooks, these are described it the patent. In brief, the patent discusses the attachment of the grapples to the quillon with sufficient strength to support a load of 600 pounds and reference is made to a casting line. With this said, it is generally accepted that using the knife as a grappling hook, which implies the act of tying a rope to the pommel and throwing the knife, could be very hazardous! A better use of these hooks are as anchor pins where knife can be wedged in some rocks or the crotch of a tree and used with a securing line off the lanyard loop attached to the hollow handle cap/pommel.
The sheath is of black rigid fiberglass-reinforced plastic. Attached to the front of the sheath is a removable black nylon pouch which contains a full-size Silva Type 12 compass with a red cord lanyard. The back of the sheath has an inlaid sharpening stone. Heavy black nylon webbing is used to cover the stone, secure the pouch to the sheath, secure the knife in its sheath, and provide a loop for a leg tie. An additional loop of black nylon webbing, with a Fastex-type closure, provides a quick-release belt loop.
This is one of the ultra rare 1986 knives stamped BUCK, 184<, U.S.A., PAT. PEND. It's built using one of the forged blanks instead of conventional blanks from sheet stock. This is the 184BK version with a black oxide finish.
(This knife is "used but never sharpened" and includes everything shown in the pictures) You can PayPal or E-mail me @ tdb7117@msn.com or feel free to call me at 303-656-1478. Thanks
$350 $300 $280 SOLD!!!
