Picture of differential tempering
I know there is a lot of confusion about differential tempering. It is done to soften the back more than the edge. it is not differential hardening. blade is fully hardened, differentially tempered for spring back and hard edge. It is usually then tempered in an oven to control the hardness of the edge. Leaves no visable temper line.
Great pics... very illustrative, and worth a thousand words. Thanks for sharing.
Nicely done,,,and explained. Thanks for the pix,,they are more informative than " finished " examples. In the raw as it were,,,,no,,not me,,,the blades...:D
JM
Thanks for the photos. Could you also post some information about how you do this and how you get the lines so even?
Thanks again,
John
I don't qualify to instruct anyone in this method. Just thought it might help clear up confusion. Edge is in water and torch on back of blade. learned in ABS school from Roger Massey.
Dan Farr
Hey Dan, if those blades were handrubbed and then etched, wouldn't the temper line show up then? Excuse my ignorance.
I re-read the first post and now I don't understand. Selective hardening is just that. Selective tempering to me implies just that, don't at the tempering phase. Why would you selectively temper something and then temper in the oven?
Also I guarantee if you took those blades to 600 and dipped in ferric the temperline would show because the ferric would attack the hard and soft steels differently. How you control the polish determines the temperline showing or not. Just my 2 cents.
I use a water tube Like this, whether I dif, temper or dif Harden.
Tempering the edge after, tempers the edge to what you want it to be
tempering or drawing out the spine softens it at a lower Rockwell
toughness here is what ever you want it to be, it depends on the heat you use..
if the back is left dead soft in edge hardening the grain
will be bigger, if the hole blade is hardened and then the back is drawn
the grain should be smaller there-for making
the hamon harder to see. I hope this helps
Check this out:
Differentially hardened katana by Howard Clark, 1086M with clay and water.
"look upon my work, ye mighty, and dispair." :)
very cool blades everybody, I especily like the katana. The way I do it is with an edge quench with only the edge getting heated to criticle with a torch. I find that for my methods it gives me better control.
BB, the old time cuttlers used to take the straw color right to the edge. The extra temper in the oven is to make sure the edge gets the right time and temperature for tempering and is added insurance.
Good example, Sabre!
I attended the same class that Sabre did and probably didn't learn as much! You can tell by looking at his knives, just awesome.
What we did was to temper the blade for an hour immediately after quenching then did the draw on the spine in a pig trough with a torch, then temper again for an hour. Pretty technical stuff! :)
I recall one fella (Myagi)in the class that did it this way and when he did the "bend test" on his blade, it came back to near straight after bending it 90 degrees in the vise. This blade passed the cutting tests as well.
Although simple to do, it accomplishes more than meets the eye. One thing that Roger Massey mentioned was that the blade needs to be cleaned up as soon as possible due to the part that was in the water will somehow etch and look pretty bad. Until you do this, you won't appreciate what he meant.
C Wilkins
for a reason, hardened high carbon
steel will rust or etch faster then soft steel
this would be why he's cleaning up it soon
after the heat treat.. just 2 cents more.
