- Dec 13, 2005
I recently started trying to use plate quenching for D2. The technique that i am using is to take the blades in the package right out of the kiln, place them on a large aluminum plate and as quickly as possible put the other aluminum plate on top. I then add about 90 more pounds of steel on top and then blow compressed air between the aluminum plates. The problem that i see is that my blades are warping. I never had much of a warping issue when i just air quenched them. I am suspecting that the time they spend on the bottom plate before i can get the top plate on is causing the problem. Does anyone else use this method? Any suggestions on what i can do to prevent this?
-John
-John
