StuntDouble
- Apr 26, 2004
This past weekend, I had trouble with our toilet overflowing due to what I thought was the flushing arm chain getting caught under the flapper valve, causing the fill valve to constantly run. After the water level returned to normal in the toilet, flushing it would only cause it to fill to the top and almost overflow again. I ran a snake through the toilet and it came up clean. After a bit, I went under the house, and checked the main line, but other than a couple small bits of debris, it was clean and dry. After a while, everything went back to normal, and the toilet flushed fine.
Today the flapper got stuck again, and the toilet ran until it overflowed. I plunged it until the water went down, then went under the house and checked the main line again. This time the line was full of water. I let things sit a bit, then went under to check it again. There was still a little bit of water in the bottom of the pipe. I went back up to check out the toilet, and it flushed fine again. I had some towels that needed to be washed after cleaning up the mess, so I ran the washer. As the washer was going I heard gurgling from the toilet, like there was air coming up through it. Stupidly, I flushed the toilet, and it did the same as before. Thankfully I cut the water off to the tank, so it didn't overflow this time.
Frankly, I'm at a loss. Anyone have any ideas of what the problem may be, or similar experiences?
