Hello
I have a kitchen knife that I have filed out of a piece of 1/16" thick, anealed 1074 (15LM) from a sawmill bandsaw blade by Sandvik. Blade length is 6". Overall length is 10". It is flat ground. I have sanded the blade to a 400 grit finish by hand.
I have two questions.
The first is, should I trim away some of the material at the thin cutting edge to prevent cracking? I originally filed it down to between 1/32" and 1/64". The sanding has brought it down to esentially zero. From what I have read here, I am concerned that the thin edge will crack when I quench the blade. If it will not crack, I would have a really thin flat grind and would only have to do the final cosmetic finish sanding and sharpen on my Sharpmaker.
The second is regarding the choice of heat treating procedures. The blade is extremely soft now with no springiness at all. I would most likely heat the blade up with a torch before the quench. Should I
a) Quench the whole blade, then temper the whole blade in a toaster oven twice at 400F for an hour each time.
b) Quench the whole blade, then temper the back with a torch to spring temper, then temper the rest of the blade (the edge) in a toaster oven.
c) Quench only the edge, then temper in a toaster oven. If I do this, would the edge still be really soft?
d) Some other heat treat procedure.
Thanks in advance for your help. I wouldn't have gotten as far as I have on my own.
Phil
Phil
