Don
There should be many good folks chime in on this problem. I think all knifemakers go through these problems and learn ways to cure them after making several blades.
Here are a couple of ideas.
The condition of the steel before you process it is important.
Are they ground as close to the same on both sides as posible?
If not the blade will warp.
What steel did you use?
What condition was it in when you got it i.e. hot rolled, as rolled,
from plate , from bar, annealed, sub annealed.
If is "as rolled steel" this could be one of the problems.
A good process is to first anneal a bar like this to dead soft. Then start working it if you using the stock removal method.
If it is forged , did you anneal before grinding and heat treating?
This will cause warp if not
Hot rolled is annealed sometimes but not always.
Buy steel that is fully processed and annealed.
Just a few small things to look into.
