- Aug 8, 2000
"In Rockwell hardness testing, a conical diamond is
first pressed with a force F0, and then with a force
F0+F1 into the material being tested. After unloading to
F0, the increase (e) of the depth of the impression
caused by F1 is determined. The depth of penetration
(e) is converted into a hardness number
(HRC) which is read directly from a scale on the
tester dial or read-out".
I was reading this info regarding the Uddeholm Elmax powder steel. At the end of the article there was this appendix.
Can somebody plz clarify this for me? Does this statement mean that the needle is pressed into the material twice on the same spot? If so is the case, then why?? What's the purpose of this procedure?
Thanks,
~Paul~
Thanks,
~Paul~
