reface contact wheel
How would anyone out there reface a contact wheel, I have a lathe but have not had much luck machineing rubber, any help would be apprecated..
A machinist once told me that he would wet the piece, put it in the freezer for a couple of hours, and then machined it. He said it made a world of difference from room temperature, go figure. I have not tried this myself.:confused:
I would definately make light cuts though.
Allan,
I use a tool post grinder with a sanding drum mounted in the spindle. Use a very coarse abrasive. Spin the wheel slow and use your carriage feed.
A dust collector is needed! Other wise it is very messy.
Good Luck,
Rob
Thanks Mike and Rob, Mike i tried the freezing method and did not get the results i was looking for. Rob i will try your method as i know you have the knowledge and experience, and thanks for sharing.
