Refit ""
Refit "and often make"
This is"and often make" that the customer entrusts to refit for me to make a handle
I to post its to refit process.
Material.Bronze.Mat slice.Antler.The mosaic nails.
[Pack root type method]
The hold originally possessed first of the hole is knocked to go in to make up deficiencies with the copper.
改裝"兼常作"
這是客戶委託給我改裝製柄的"兼常作"
我來貼貼它的改裝過程吧.
材料.青銅.墊片.鹿角.馬賽克釘.
[包根式作法]
首先把柄原有的洞用銅條敲入補上.
Whet the surface even.Draw the part that to cut off.
將表面磨平.畫出要切除的部份.
Appearance after cutting off.
切除後的樣子.
The knife postses a sellotape to protect.Pack bronze to protect a hand.
刀子貼上膠帶保護.裝上青銅護手.
The set goes into a mat slice.The antler digs hole.Prepare the last gum.
套入墊片.鹿角挖洞.準備上膠.
After ascending a gum using a rubber band is fixed.After the aridity again grind and pack mosaic to nail.
Finally throw light.
上膠後用橡皮圈固定.乾燥後再研磨及裝上馬賽克釘.
最後拋光.
