• The Wait Is Over. From this thread, orders for the 2023 BladeForums Traditional Knife are open & here's your handy order button.
    OPEN TO ALL MEMBERS WITH GOLD OR HIGHER PAID SUBSCRIPTIONS OR have 25+ posts in the Traditional Forum Preorder price is $160 shipped CONUS, price increase on 9/25 11:59PM when ordering opens to anyone on the forums
    User Name
REKAT Pioneer II Tanto point Review
Hi,
Just got this knife yesterday. Here's my likes and dislikes.
REKAT Pioneer II Tanto folder review
Likes
1) Shape of handle is very pleasing to the eye.
2) Flawless joining of G10 scales to liners, no visible gaps of any kind.
3) Thumb stud was comfortable to use repeatedly.
4) The action was not as smooth as my AFCK, but it was much better than alot of other knives I've tried, eg Voyager, Kershaw Liner Lock, etc
5) Lockup is super solid, no play at all in any way. Love the rolling lock.
6) I love the finish of the blade, a no-nonsense non-shiny finish, very utilitarian look, perfect for a working knife. No qualms about scratching it.
7) Edge was scary sharp, tried it on facial hair and it did fine.
8) Tanto blade had a slight curve to it, and was not ground at a sharp angle. With repeated sharpenings I'll hope to reprofile it to look more like a drop point-tanto marriage.
9) Closing mechanism is quite easy to operate after some practice.
10) The price is reasonable, and the fit and finish good.
Dislikes
1) The one thing that spoilt it for this excellent knife in my opinion, is the carry clip. Its situated too near the bottom edge of the handle, and is really uncomfortable when used moderately or for more than one or two cuts. How such an obvious design flaw could be overlooked is beyond me. The position of the clip defeats the ergonomic shape of the handle. A real pity here. Any advice on how to remove the clip will be appreciated.
2) The tanto blade was hollow ground, kind of an oxymoron if you ask me. The reason I wanted a tanto was because a strong tip is important in what I do, and a hollow ground tanto tip weakens it significantly.
3) There's no lanyard hole. I initially wanted to remove the clip and wear it around my neck on a cord, but without the lanyard hole, this is also not possible.
Minor details
These are minor points that I noticed.
1) Traces of blue locktite on the screws were quite visible. They can however be scrapped off with a nail.
2) The hex screws looked used (as they should be). I can't understand how Benchmade manages to put the knife together, and tighten the hex heads without the screws looking like they've been used at all.
3) On one of the scales, the profile of the scale and liner did not entirely match. The G10 scales covered a little more area than the liner. However, this is a minor workmanship thing and should in no way affect the knife's function.
After some practice, I've found the knife is easiest to close by facing the edge to the side (not up or down) and operating the lock. This helps to make it much easier to unlock the knife. When I was trying to do it with the edge facing up, it was quite difficult. Remeber to keep those fingers out of the way.
All comments welcome.
Pang
Pang - I have an old-style drop-point, which I also like a lot: very strong & sharp!! But that's a big sucker for it's size, if you know what I mean. Modifications I have made:
1) Dremel an index-indent in the clip, to match that of the scales and liner. It's easy to do and makes it SO MUCH more comfortable in the hand, removes your major ergonomic concern.
2) round all the sharp edges of G-10/corners of the steel lines. SMOOTH - the proverbial "bar of soap" until you grip it, at which point the shape of the handle locks it into your hand.
3) file thumb serrations in the liners & G-10 on the back neck of the handle, where the handle meets the blade spine. Makes a significant improvement in "grippiness."
Modification in progress:
4) take knife apart, drill/dremel out most of the steel in the liners to remove a lot of weight.
NOW we're talking a sweet knife!!!
modifications: half the fun of having a knife in the first place . . . .
The beatings will continue until morale improves.
If you want to carry it around your neck, you may want to consider a sheath. There are quite a few member who make custom seaths. Try a search on it.
Howie
