I need to dissassemble an old folder I picked up in a trade, unfortunately the button head torx screws holding the handle scale on are buggered and can't be removed. Is there a screw remover tap available to fit small torx screws or do I need to use a drill press and bit to remove the screw head. Also, if the screw was loctited in (which may have contributed to the cause of the original damage to the screw) is heat the only way to loosen the loctite?
Thanks,
SKH
Thanks,
SKH
