Ebbtide
- Aug 20, 1999
I see alot of mentions of paracord/lines in people's e-kits. This is all well and good. But please learn a few good knots. Too many times, while camping, I see people ruin perfectly good lines because they tie granny knots, can't get 'em out and cut the line!
The knots to know are:
The good ol' Square Knot
The Bowline (SP?) pronounced bo-lynn
The Prusic (Again SP?)
And one of my favorites, which has no name that I know of, an overhand knot with a double line. It is just like the first step in tying your shoelaces, but you put a loop thru the knot instead of an end. If you pull on the ends of the line the loop will pull out. Recognize it? That is really handy for tying off to trees and keeping the line TIGHT. If you tie the loop in before the tree then go around the tree and to the loop, you can cinch that puppy up tight. Very important with stretchy stuff like paracord.
The most important thing about all of these knots is that they come out easily.
2 more thoughts: If you need to tie 2 lines together, tie them bowline to bowline, then they will come apart when you want. The other is...If you only need 10' of your 50' line Don't cut it!!!! Loop up the extra and tie it off. I am amazed how many people do that and at the end of the year have 43 1/4' of knotted together mess.
I realize most of y'all out there know this stuff, but I thought it should be said out loud.
I would enjoy hearing your thoughts, tips and tricks too.
Can it core a apple?
