S7 question
Since S7 is an air hardening tool steel it might be better to differentially temper rather than differentially harden.
I'm sure you could differentially quench or temper S7 but there is probably no good reson to.
Using Crucible's data you could fully quench and then temper at say 400° F yielding a blade at 57 HRC and 125 ft-lb.
You would have to draw the spine to over 900° F to get it any tougher.
Code:
S7 Typical Properties
Tempering 	HRC  	 	Charpy ft-lbs
Temperature
°F
300 	 	59 	 	85
400 	 	57 	 	125
500 	 	55 	 	125
600 	 	54 	 	115
700 	 	53 	 	105
800 	 	53 	 	105
900 	 	52 	 	120
1000 	 	51 	 	150
1100 	 	47 	 	190
1200 	 	41 	 	–
I read that at Crucible's web site.They also said that larger sections could be oil quenched to attain maximum hardeness, of course there idea of a large sction more then likely is large indeed. I thought that this might open up the the chance for S7 to be differential heat treated. Just wanted to get some opinions on the matter. I do fear that warping might be a issue. Thanks for the replys guys.
