Gravelface
- Nov 8, 2005
Brand New in Box, preferably local pick up or meet at Blade. Looking for knives, maxpedition equipment, pistol (.45) ....open to suggestions. Will Ship, but would cost extra because I will pack the hell out of these things!
I also have a Brand New In Box Samsung 22" Computer Monitor SyncMaster 225bw
Description:
The Samsung LN-S2352W 23" LCD TV is a compact Integrated HDTV panel. This slim and lightweight TV sits smartly on the included stand and is picture perfect wall-mounted with the optional accessory Wall Mount Kit hardware.
It has HDMI for single-wire digital sound and picture perfection, freeing you from tangled and messy nests of audio and video cables snaking. You can also hook-up your personal computer for wide-screen spreadsheets etc., creating family gallery showcasing slide shows of your digital photo album on this high definition flat panel. The LN-S2352W with its optimized game mode was designed to delight gaming enthusiasts, without compromising on the features that have become synonymous with Samsungs quality HDTV LCD screens.
Features:
• HD 1366 x 768 Pixel Resolution
The Samsung LN-S2352W has a high pixel count that provides fine detail for high-definition TV programming (720p, 1080i) as well as DVD movies. It also accepts signals from a variety of analog and digital sources.
• 23" Widescreen
Dont miss a detail with this 23" Widescreen LCD screen.
• Enhanced Game Mode
Samsung worked closely with Microsoft to create a special Game Mode that optimizes image quality, sound and response time for more realistic video game play with just a single touch of a button. The Game Mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games.
• 3000:1 Dynamic Contrast Ratio
While viewing either very bright or very dark scenes, it can be difficult to distinguish images which blend into the background. Dynamic Contrast drastically diminishes this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
• 170° Viewing angles
This LCD TV features an extremely wide viewing angle of 170°. You will always get great image quality, whether you are sitting directly in front of the TV or off to the side.
• PC Compatible
Connect to your PC to play PC games, or just to se your files on a larger sharper screen.
• Picture-In-Picture (PIP)
PIP enables convenient simultaneous viewing of TV programs and video or PC sources.
• Fast Response Time
8 ms response time minimizes blurring of moving video.
• V-Chip system
V-Chip Technology gives parents the control they need to monitor the programs their children watch.
• Energy Star Compliant
Energy Star compliance reduces energy consumption by up to 25% compared with standard TVs.
• Clock On/Off Timer
this is the perfect way to wake up to your favorite morning show, or set a time to turn off the TV so it doesnt stay on all night. Can also be used when youre out.
Specifications:
Display
Screen Size (Diagonal)
23"
Aspect Ratio
16:9
Pixel Resolution
1366 x 768
Brightness
Not Specified By Manufacturer
Contrast Ratio
3000:1
Response Time
8ms
Viewing Angle
170° H/V
Video
Video System
NTSC
HDTV Compatibility
Yes
TV Scan Lines
SDTV - 480i
EDTV - 480p (Progressive Scan)
HDTV - 720p, 1080i or higher
TV Tuner
NTSC (Analog TV broadcast), ATSC/QAM (Digital TV Broadcast)
CableCARD Slot
No
Speaker
Sound
Stereo
Power
3W x 2
Orientation
Horizontal
Input/Output Connectors
Inputs
R/F Input x 1
HDMI x 1
Component x 2
Composite x 2
PC X 1
PC RGB x1
Outputs
Headphone jack x 1
Control Port
No
Convenience
Picture in Picture (PIP)
Yes
Digital Media Slot
No
Menu Language
English, French, Spanish
Remote Control
Yes
Tilt/Swivel Range
Wall Mountable
Yes Vesa Mount Compliant
Power
Power Requirements
AC 110-120V 60Hz
Power Consumption
100 W
Yes
General
Dimensions (WxHxD)
No Stand: 23.4 x 16.6 x 3.0" (594.4 x 421.6 x 76.2mm)
With Stand: 23.4 x 18.7 x 8.5" (594.4 x 475 x 215.9mm)
Weight
18.1 lbs (8.2 kg)
Description: The Samsung Syncmaster 225BW-BLACK is a 22 in, flat panel computer monitor. Compared to other flat panel monitors on the market, it is very inexpensive at around $390. This display features a 1680x1050 native resolution. Weighs 15.2 lbs.
Pros: Has 1680x1050 resolution, which is higher than some similarly priced monitors. Also, this monitor has 16:10 aspect ratio, which is somewhat more favorable than some similarly priced monitors. By way of comparison, the average cost of a product with this favorable an aspect ratio is $570. This LCD screen has a relatively good contrast ratio (700:1), which generally makes it easier to see color distinctions against a dark background. This device is compatible with both the Mac and PC platforms. Its wide viewing angle (160 degrees) is useful whenever the screen is being viewed by more than one person at the same time. Accepts DVI input.
Description:
Features:
• 23" Widescreen
• PC Compatible
• V-Chip system
Specifications:
Display
23"
Aspect Ratio
16:9
Pixel Resolution
1366 x 768
Brightness
Contrast Ratio
3000:1
Response Time
8ms
Viewing Angle
170° H/V
Video
Video System
NTSC
HDTV Compatibility
Yes
TV Scan Lines
SDTV - 480i
TV Tuner
CableCARD Slot
No
Speaker
Sound
Stereo
Power
3W x 2
Orientation
Horizontal
Inputs
R/F Input x 1
HDMI x 1
Component x 2
Composite x 2
PC X 1
PC RGB x1
Outputs
Headphone jack x 1
Control Port
No
Convenience
Yes
Digital Media Slot
No
Menu Language
Remote Control
Yes
Tilt/Swivel Range
Wall Mountable
Power
Power Requirements
AC 110-120V 60Hz
Power Consumption
100 W
Yes
General
Dimensions (WxHxD)
Weight
18.1 lbs (8.2 kg)
