The more I use it the more I am impressed! Very comfortable, very tough, and really takes an edge!
I am also considering a kydex drawpoint sheath from Mike Sastre. Here is the response he sent me: "For the SERE 2000 I've made some
Security Sheaths (backpackstraps, clinbing harnesses, etc.) and an IWB
(Drawpoint) sheath with the blade deployed. The Drawpoint sheath could also
be adapted for regular belt wear if desired. Base price for the Drawpoint in
Black or Olive Drab Concealex is $35 and comes with a reversible belt loop
with pull-the-dot snaps, that is adjustable for carry angle and edge
orientation. A "sport clip", belt plate, or TekLok is an additional $5 as is
Carbon Fiber Concealex. The Drawpoint is a "speed rig" meant to be used with
James Keating's Drawpoint Method of response to an attack. There is a minimum
of material covering the handle to facilitate grip aquisition, yet still
enough tension holding the knife in case you are in a little "rough and
tumble". Let me know what your carry needs are and I can individualize the
sheath for you."- Mike Sastre
Mike's email is videosas@aol.com
Dennis Bible
