So... did a metric f$%&ton of research on sharpening technique, sat down with my Sharpmaker and attacked my Sebenza (I know, I know, but it's my EDC and I dulled the edge.) I did see immediate improvement and over the past few days my technique has improved, but my early mistakes are haunting me.
Looking closely at the blade (no magnifying lenses or anything) I can see that one side along the flat portion of the blade has been ground more than the other, and that the angle is a bit different in fact. I've been working away at the knife to even this out, but it persists. The edge is essentially "off" to one side a bit. Not rolled; it just hasn't been ground evenly and as such it's not centered.
The curved portion hasn't gotten as sharp as the flat portion yet; it's most evident when testing the edge by cutting newsprint as the portions cut with the curved part of the blade are rougher and require more effort. It also shows when I attempt a hair-popping test; the closer I get to the tip, the fewer hairs that the edge grabs onto.
At least, I haven't destroyed the tip (yet.) I've kept myself from pulling the knife off the hones, instead stopping the draw with the tip still on the hone. I've slipped a few times, though, and between that and my inconsistencies, the tip isn't in very good shape. It's still "pointy" but the edge is dull. It also looks like it may have been rounded or blunted very slightly, but I could be paranoid and over-analyzing it. More than likely, it's still dull because it just hasn't been sharpened enough, but at least it's still a little pointy.
Is there any good way to make sure I get the edge centered again and get the angles on each side even? Does this even have anything to do with cutting performance as long as the edge is still facing forward? (I keep remembering that chisel grinds do actually work...) And last but not least... what's the best way to keep that tip nice, pointy, and sharp? I tried freehanding the tip with one of the stones, using it like a file, but it seems that all I accomplished was some scuffing-up of the finish.
