Sharpening my Hunter
Moosez45
Custom Antlers, Factory Knives...
Moderator
I'm new with convex edges, and I have been stroppin' it for the hair raizing edge I'm lookin' for, but, I have never really sharpened one before. I have read a bunch of stuff on convex, but I am more of a V egde man myself. Has anyone put a V edge on a FBF before, and how's it workin' for you? If not, a couple of good tips might be all I need to get going on this convex thing. Thanks ya'll. Moose
Have you checked out the instructional videos on knives ship free? Bluntruth4u on YouTube has vids on how to take a beveled v grind to a convex grind. Hopefully that helps.
Moose, not sure if you are using any black or green compound or just stroppin on plain leather. Typically a strop is to dress an already sharp blade. Some use a mousepad with different grit papers and then finish off with the strop. If my edge gets really dull, I will wrap some 600 grit around my strop, or even use a fine DMT, and then go to the compound and finish with plain.
Watch the vids over at KSF - they are very good.
Just take your time and maintain the angle. Start with the angle lower than you think you need to. The problem I had when I transitioned was that I was trying to start at the same angle I was used to when sharpening a V grind. Also, you want to stop your strokes before you reach the end of the strop, and lift the blade up.
I think you will really like the convex edge Hope this helps.
Color your edge with a marker before starting, so you can see where you are removing steel. I still do this every time. Really shortens your sharpening time.
If you use a soft substrate, like a mousepad, use very light pressure. I use leather to back my sandpaper. Its stiffer and you can use a bit more pressure. I start with 220 grit paper, and go to 400, then strop. Some guys go all the way to a mirror edge. I like mine toothy.
I did thank you. It helped.
I have 4 strops different grits, I use a powerder Crystalon, Chromium Oxide, Jewlers Rouge and Emory Cloth 800gt. One is canvas, and 3 are leather. My canvas one is two sided, and is charged with the Cryst/JR setup. My leathers are backed on wood, my Canvas is a hook free standing. My Chromium Oxide is a 4" roughed leather and its the cat's meow for that polished edge.
My concern was in angle, as, what I read, a convex edge rounds from the profile grind to the center of the edge, I am unfamiliar with the angles that you speak of, as I see it as rounded, but like I said, I'm a newb when it comes to convex. I have always prefered a v edge on all my blades, Andy's is the first blade that I bought with a convex edge.
I have convexed a few edges, but they didn't work out for me, perhaps, because I done it wrong. Thank you for your info, it has certainly helped.
Ok, I got the leather, sandpaper, sharpie, and strop, now I just need the guts to do it. So far, I've used my canvas strop, Cryst/JR, and let out a little tension to allow a slight bow in the fabric, and it gets hair poppin sharp, but, I was thinking I might have to edge this thing soon, as I am using it daily for everything from wood to meat. No patina yet, as I am using 0000 steel wool to keep it shiny, and I'm polishing it with a paste/compound weekly, and I'M LOVIN' THE SHINY. I'll let it patina up soon, but for now, you can pull it out in the dark and reflect light, lol.
Thanks a ton guys, I'll get my nerve up and post about it after I've done it, I just don't want to screw up my Hunter, not that I can't fix it, I just don't want to have to.
Moose
Let us know how it goes. As soon as my convex's dull up, I'll be in the same boat. Convex grinds are new to me.
Convex's are alot easier to maintain on a strop once you get the edge. :thumbup:
Moose buddy, I'm just like you. My Hunter was my first convex and I finally had to break down and bite the bullet last week. Its the first time I really gave the edge some attention. I have to admit that there was a learning curve that I didn't expect. But once I got down to it, it wasn't that bad. Just like anything else that's new, it takes some patience and a sense of humor to get used to it. I glued a piece of mousepad on a 2x4 scrap, got out some sandpaper and got to it. I didn't have a strop, so I found out why they are nice to have. You can only go so far without it. But I've got one now!
Let us know how it works out for you.
I will keep ya'll updated. I want to do a mirror polish on it also, and I got the stuff for that, already. I think that since its an first run of full convex, it would look so good as a mirror. Just a thought. Moose
PS, I get to play with Joezilla's Terrasaur here in a few weeks, so, I'm excited. I listed my Christmas wants as an OD Izula, Junglas, and a Terrasaur, but not necessarily in that order, LOL. Andy, you got any Terras on the books or you gonna make me go to a dealer? LMAO.:D
Moose
Good picks! I also have an Izula that I had someone convex for me. That one was the desert tan and a black one untouched sitting in my project survival kit until my safety orange one comes in a couple of weeks (knifeworks pre-order) Junglas is on my wish list too.
Definitely don't get let yourself get discouraged with it. I managed to f* up a BRKT gunny so badly while I was learning that it had to go back to their 'spa' to get set back to zero. Since then I have convexed 2 Izulas, my ESEE-3, and am a total convert. Very easy once you get used to it. The hardest part for me is getting the last bit of the belly towards the tip super sharp but it's think it's just bad form and probably giving it too much angle/lifting too much when I get to the tip.
Don't put a flat secondary on it, Moose!!
[youtube]Rt44uDP82CE[/youtube]
[youtube]2j0wNu4BpYg[/youtube]
[youtube]8qlM2JDJkQY[/youtube]
You can do it, brother. It's easy.
Iz
OH YEAH!!, Now we are talkin' video tutorials. I can live with that. Iz, you tha man. I ain't got the balls up yet to do it, I'm afraid I'll mess up my Hunter. I may wait until I get my Terra, so, if I do screw up, I can send it back to Andy to "spa" it up, and still have my Terra to play with. :D
Thanks Iz.
Moose
Moose, Let me know if you need help. I am actually pretty good with convex edges but suck at Vs. I reprofiled my Laconico to convex.
I need to sharpen my Nessmuk but like you need to work up the guts to do it. I bought it second hand and someone put a "V" grind on it so it needs to be taken back to convex, and I'm scared to mess it up.
Yeah, with me, when I pony up the dough for a nice blade like the Hunter, I don't want to screw it up, specially when its hair poppin' sharp now, it just one of those things I gots to learn. I'm thinkin' about startin' out with another knife, till I get better at it.
I'll have to take you up on that when the time comes, I'm gonna practice some to get more confident. Sorry for this weekends fall though, between my lawyers and my girls being sick, it was a crappy weekend indoors. I hate it when the kids are sick, but, hey, I knew the job was dangerous when I took it.
Moose
Moose
