- May 17, 2004
When sharpening a new or reasonably sharp knife, do you have to get a burr again? At what point do you know it is time to get a burr or whether it is just OK to "touch it up"?
I don't raise a burr when "touching up". For a quick touchup, I just use the Spyderco Sharpmaker on the corners. By using just the corners it acts like a steel, realigning the edge and with the white stones, removes minimal knife steel. Best of both worlds. Even with a full sharpening on bench stones (burr raise), I will steel the edge first with a smooth butchers steel or fine cearamic rod. If I see nicks or bright spots when looking at the edge with a bright light after a touch up (bout 5 to 10 light strokes per side), then it's time for me to raise a burr.divebuddydave said:When sharpening a new or reasonably sharp knife, do you have to get a burr again? At what point do you know it is time to get a burr or whether it is just OK to "touch it up"?
spyken said:I agree with stropping for light touch ups. Altho I use a leather strop with the lee valley green compound myself.
Morgoth412 said:I feel that everyone has contributed great stuff here, but I think they have left out the "other" missing link between touchups/steeling.
Stroping! It is so easy and effective. This is the procedure for me:
1. Be wearing a pair of jeans
2. Bend you leg and make the jeans go tight around your leg
3. Lay blade on upper leg and using a consistant angle drag it edge trailing to you
4. Then reverse side and drag edge trailing away from you
5. Repeat a few times and then test the edge; Should be razor sharp again
If that doesn't work then it is time for a touch up on the Spyderco Sharpmaker.... And if that doesn't get it ultra sharp it's time for the full sharpening.
-Kevin
