I am beginning to shop for a DC motor in earnest. Time to upgrade. Hoping to build a grinder in the next year, and plan to rebuild my Grizzly and use the DC on it for the meantime. I have considered step pulleys, but after hours of calculations and thinking, I would have to decrease the size of my drive pulley significantly on my Grizzly in order to get to manageable speeds, and I think I would be better off going with DC.
Then I can always switch the DC to my new grinder when I finish it.
I wanted to ask you all if you could give me any pointers and answer some questions. I have a few sources for buying new, and all seem pretty pricey. Anyone have a source for purchasing new motors at great prices? I plan to camp out on Ebay, understand many have gotten great setups there. I also have access to the surplus machinery catalog and a place called Roys Store. Any other places you would recommend checking out?
This what I know.
I have a controller rated for max 2HP, so that is what I would like to get. I know I need a permanent magnet motor that will run 220V.
Here are my questions.
Are there any brands I should avoid? I know Leeson and Dayton are pretty good.
Are all DC motors reversible, or should I look for this feature?
Any reason I should pass on used or rebuilt motors? I thought about checking out my local motor shop, and seeing what he has in rebuilt motors. If you would recommend used/rebuilt, what sorts of tricks can I use to make sure I am not getting an anchor?
Does the frame config matter if I am going to use a pulley?
Which max speed would you recommend? I was going to get 1725rmp, but was wondering if I should consider 3500rpm. With a 4" or 8" drive wheel, that is some serious fpm! But if I get a higher max rpm, will I still have as much fine tune control for the slower speeds, finer belts, etc.?
Is there anything else I dont even know I dont know?
Lastly, if anyone out there has a motor, or knows someone who does, and wants to sell, I am very interested. It would really help me out.
Thanks for all your help.
Brome
This what I know.
Brome
