Let me tell you a thing or three about smoothness.
Doing the work I do I get to handle many knives. I see some that strike me as super nice and have bought one for myself only to find that just because the one I had here for a pocket clip was silky smooth doesn't mean the same model I bought for myself will feel the same way. In some cases you would have to carry the knife and use it a good while to get it where it was when I saw it here. In others they are closer.
On most every Emerson I have bought new from the EKI factory they have been anything but smooth. I hear tell some get out there and I finally managed to get one in that HD7 I bought. Until then I thought it was a hype story. None of mine came that way. All had to be carried and used for anywhere from three to 10 months before I'd call it smooth. Most came grainy and gritty feeling and needed lots of work to get them ironed out to where I like em.
Smoothness is attributed to the pivot barrel tension. It is related to the type of thumb stud as well as the placement of the stud on the blade also. On some knives like my Alias II that I had I turned that folder into a much easier smoother feeling folder by simply changing out the thumb stud to one less conical shaped that stuck out a bit farther so my thumb could get a better purchase of it to rotate the blade out. It took the knife from crappy to where I missed the stud with my thumb more often than catching it to being a nice EDC.
Time and wear is also a factor for smoothness. Teflon and nylon washers will be pretty smooth right off the bat, but nylatron and Phosphorus bronze washers tend to get better and better with age. Proprietary pivot mechanisms like those Duncan uses or ones with some other type bushing like the Sebenza also can contribute to the overall feel and interpretation of smoothness or lack of it.
What I'm saying is that just because one guy says the J.W. Smith folder is the smoothest made or just because another says its a Jonn Connely or an Emerson production doesn't really mean squat. Each knife is unique and while some companies or makers may be more consistant than others the case is usually that you have to accept the fact that no two are exactly alike. You shoot for an ideal and you know where that is. You just hope you hit as close to it as you can with each one you make. Some fall shorter to that ideal than others while others make the grade.
If its that important to you I'd say buying the folder you are that picky about on the net is a crap shoot at best. Go to a show, find the exact knife you like and can live with and buy that very knife. Thats what I'd do.
STR
