So it is called width or height?
The distance from the edge to the spine. I've heard both being used, but that irks me because I like conventions.
Kitchen knives seem to use "width." But the grind is called a full-height grind... Which school of thought are you from? And why?
Width = blade or handle thickness
Height = distance from edge to spine
Because the thickness of the blade is the width not height.
Isn't the thickness of the blade the... you know... thickness? :eek: While I've heard tall knives called wide, I've never heard thick knives called wide before.
Here's an example. Regular: http://www.amazon.com/Wusthof-Class...MEH1/ref=sr_1_1?ie=UTF8&qid=1316614546&sr=8-1
Wide: http://www.amazon.com/Wusthof-Classic-8-Inch-Cooks-Knife/dp/B00005NCX7
I think of it like I would in geometry:
Picture the handle sticking out of the right side of the cube where the shadow is. So thickness of blade = width and distance from spine to edge = height.
Just my opinion though.
I'd say it's width if you held the knife vertically. If you then held it in a horizontal orientation, then I'd call it height. ;)
when i list the dimensions of a knife, i put down the knife length. blade thickness and width from spine to edge.
I have always thought that the blade has only three dimensions - they were called: length, width and thickness. Wide blade is not the same as thick to me.
As for the height - I understand this term used with grind, but used in relation to blade it is meaningless to me. "High blade" - huh! Does that mean something ornate, fancy, expensive?
I've always thought it was length, width and thickness as well. Length, width and height make sense from the standpoint of geometry, but I don't think people list knife dimensions that way.
Hm, I guess this is one of the more subjective aspects of knives :confused: width seems to be the majority, though.
