Spark test and an "anvil"
Well, I tried the spark test on a piece of metal I want to use as an anvil, and got relatively few, yellow sparks. Fairly bright, but not that zinger yell--more brass-colored. Do I have cast iron here? I think so but I don't really know how to interpret sparks. There are some pictures of the piece at the link below. It looks to me like a mount for some kind of pole or rail--maybe a guard rail on a bridge?
http://www.geocities.com/gwinnydapooh_2000/anvil1.html
Isn't scientific but drill a small hole someplace where it won't matter, not too deep, just enough to see if the metal comes off powdery. All the cast iron I've drilled a hole in did that.
Take care!! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!
Cooper Custom Knives
Buzzards gotta eat, same as worms!!!
OK, thanks. I can't find any casting flash or seams, but it has that grainy surface. I'm going to use it anyway until it breaks, but if it's steel I want to harden it and if it's not I want to mount it right away since the forge is almost complete.
sense the one end is aready broke i would set it up where its stable and hit that end with a good size hammer use some force if it cast iron it will break fairly easy. i had a 40lb cast iron vise that had an anvil was straightening out a piece of metal and the anvil cracked
Looks like cast iron to me, by the shape of it. I think You have a guard rail stanchion from a bridge. Rail car coupling and forklift forks, chunks of mild steel at least 4" square or round would work.
I know one guy that used a sledge hammer head for a light anvil.
Sola Fide
