What is the best type of spray adhesive to use for attaching sandpaper to a disc sander or granite "sanding plane". 3M makes several types, 77, 72, 75, 76, 90, 74, and 80 (as listed in my McMaster Carr catalog). Ideally I want something that I can spray on and stick the paper on, maybe position it a little, sand some, then be able to remove the paper and slap another on with out a messy cleanup each time I switch grits, but it also has to stick strong enough to hold the paper on a disc sander and be nice and flat. Basically what I want is the same adhesive used on the back of PSA discs, but in a spray can.
I have heard 77 (described as "General Purpose") as being a good one. 72 is listed as "Pressure Sensitive" which sounds like it would be more aplicable. I called several woodworker supply places and they didn't give me much helpful info, so here I am (I know, I should have come here first!)
So what have you guys found to work best?
Also, what is the best cleaner-uper for this stuff?
Thanks again, everyone
Wapiti
Wapiti
