- Mar 26, 2000
Help me guys!!!!!
I cut the wood from a standing dead tree in July, 1999 blocked it then had it sitting on a rack above my forge for 2 months. Then I sent it out to be "professionally" stabilized. I have had this peice of stabilized wood in my shop for about one year.
I ground the block to 95% shape then attached it to the blade with 24 hr epoxy. Let it sit 48 hrs then drilled a 6.4 mm (.253 in.) hole for the .250 thong hole tube and installed it with 24 hr epoxy and finished and polished the handle.
I picked the finished knife up last night, 3 weeks after it was finished to find the handle split as per photos. For three weeks the blade has been in the house. It was ok 4 days ago. This is the one you saw Rob.
The hole in the handle was not a tight fit on the tang. and the side walls of the wood are at least .200 thick with the tang going about 1/2 the way up the handle.
Any Ideas as to why the stabilized wood split???? This is the first time I have seen this happen.
Robert
Flat Land Knife Works
rdblad@telusplanet.net
http://members.tripod.com/knifeworks/index.html
Robert
