- Oct 8, 2001
Well I've been busy these last few days. I got another one of these great knife kits from www.KnifeKits.com, and it has been consuming my time. The problem with knifemaking (...and life for that matter!
) is once you set a standard for yourself, it's *hard* to do anything less.
I wanted to try a bigger knife, and also wanted to do something in stag with all those slabs Darrell Ralph has for sale. So I bought a set, and BOY did it take some work to trim them down to fit. But trim I did with the help of a belt sander. They taper nicely outward at the end of the handle. I also cut a piece of Rosewood for a back spacer.
Going further, I wanted to really dress this up a bit. So I did my 'Lightning Bolt' filework on the whole blade, as well as some careful pattern work on the liners. (This was the hardest part of this whole project.) Actually, I didn't use a file at all, but used rotary stones for all of the work. Measured and scribed marks with machinist's dye and went at it!
Since the bolsters come pre-drilled for the clip, I needed to use it. So I styled it, keeping with my liner filework pattern. I gave the blade, bolsters, clip, and liners the hand-rubbed finish, and thinned and modified the thumbstud for a better grip. Lastly, I carved out a small cutaway for the liner access to close it.
The action on this knife is unbelievable! The blade swings open effortlessly, clacks tight, and closes dead center with only .010" liner clearance on each side. The mechanicals couldn't get any better for any price.
I'm sure proud of this one! It took a lot of work, and even more forethought, but it was well worth it! Hope it inspires you too!
Coop
Coop
