- Oct 26, 2000
How the heck do you do it? And how do you keep the grinds flat when you're flat grinding on the platen?
I've been working on a straight blade all evening and have a pretty good result going but I'm flat grinding on the platen and getting some chatter. Is that where my unevenness is coming from? Bear with me as I attempt to explain my method.
One side looks pretty good and is almost perfectly even. That's the side that I'm pulling to the right with my right hand. The other side is not as flat or even and I was pulling that with my nondominant left hand. For a while I was doing pretty good and had the plunge lines well established and even but my grind lines were off and wouldn't straighten out. Finally I decided to just flip the blade over so that it was facing the oncoming belt and grind that second side by pulling with my right hand also since I have better control with my dominant hand. I got slightly better results (flatter) but the grind lines are way off and I can't seem to correct it.
Should I just get a sanding block and finish the thing by hand? It is SOOOO close. If the damn grind lines were a little more even.
Any help would be appreciated. Thanks.
Peter Atwood
email: fountainman@hotmail.com
Peter Atwood
