- Apr 6, 2003
I received one of the first 50 Blade-Tech produced Tarani folding Karambits yesterday from the big brown truck.
Initial inspection showed the blade extremely tight fitting and some effort to deploy quickly as I'm accustomed to on other high end folders. This will need some breakin period and many openings and closings to get it where I want it.
The blade came very sharp but I still touched the ceramics to it briefly and it is where I want it now.
It appears well made overall. The serrated thumb placement after deployment are the best I've seen.
They have sharp teeth, yet when held are not uncomfortable, very positive grip.
The "ring" at the rear of the folder will take some getting used to as well. Th ring does make it very easy to grasp the folder out of the pocket. Likewise, the ring is big enough and either the index finger or small finger of the hand easily slips into and out of it dependant on whether you are holding it reverse or sabre grip for use.
After a day of playing with it I have not cut myself "yet" but I'm sure I will as I do with any new folder I play with. The fingers and hands need to ramp up through muscle memory and I think at this time will take more effort on my part than a normal tactical folder would. Thats not surprising and certainly not indicative of anything wrong however. Its just a whole new ball game.
In drills yesterday I can already see this will be quite the defensive knife. I like the blade being only just over two inches in length. Should not have any issues in any locale in the US unless knives are restricted completely from that area.
I have modified some of the quick defensive techniques to work around this knifes design and it appears initially that this knife may be better at some and put restrictions [ they'll need modification as well ]on others used by a traditional tactical folder in defensive moves.
More to follow. I like it and feel once it has loosened up some for faster depolyment from the pocket this will make one hell of a defensive knife.
Brownie
Brownie
