tempered glass
hi guys,,what is the best glass to use on my platen to grind.?should it be tempered, or regurlar glass,,,need some advice,,thanks. royboy
say andrew, do you cut your own glass,or what?any ideas be sides a shop,thanks for the info, royboy
I get the glass cut by a glass shop. It cost me $1.50 a piece. I smooth and bevel the edges on my belt grinder. When doing this go slow to start or you will flake off pieces of glass. I start at 120 grit and work down from there.
i have never figured why any one would use glass on his platan if you just want it flatput a piece of flat steel on it with brass rivets when it gets worn replace it with a fresh piece if you want a nice bump free finish contact glue a piece of leather on it
All that is not Given Is Lost
Gerome, I use glass because it provides a very slick surface that stays flat with the exception on small chips at my workrest where profiling hammers at the glass. When I push my belts hard against the glass there is less friction between the glass and the backside of the belt when compared to steel. So I guess the benifit is a flat slick surface that can easily be replaced.
