- Jul 30, 2004
The HI Kerambit... some observations, & things nobody (I think) has mentioned...
1. It balances perfectly. Right on that little finger groove. The weight of the ring counters the weight of the blade, and the break-even point is right where youd want it to be... the front finger groove, thusly making it feel very light in the hand.
2. With its false edge, this knife can be used to thrust, to my surprise. I thought they only had a raptor-claw function of slashing... noooo. She punches holes surprisingly well.
3. The mirror finish was unusually good, but I didnt realize the blade has mini-fullers, like a BDC. This has to make it stronger, lighter too. Plus it looks great!
4. You have a choice of grips with the k-bit. If you put your finger thru the hole, you wind up with a grip pretty far to the back. Ignore the ring and you great an overall better balanced feel. But if I was using it where I could lose it (at sea, like cutting rope or prop obstructions), Id be putting my finger thru the ring for more positive retention...
So, HI kerambit guys, what do you like about yours? What tricks of use have you found?
Ad Astra
Ad Astra
