- Jan 24, 2001
Well, for all of you who followed my last post on trying my first piece of damascus, I did manage to forge weld eight layers of steel together. But the process did not go without incident
I staqrted with 9 layers, eight layers and a long piece of barstock on the bottom to use as a handle. Ground each piece of steel clean on both sides, stacked them up, and wired them together as per Jim Hrisoulas in his Damascus video. I put the wired up pieces in the forge and started them soaking. I think I was using wire that was too thin(tye wire). Before the peices in the middle were hot enough the wire started stretching and all the pieces started moving around. I fluxed real good and tried to line the pieces back up on the long piece of barstock, then I stuck it back in the forge all balanced on the long piece of barstock and brought it up to a welding heat. Pulled it out, set it on the anvil and gave it a series of taps. Put it back in forge, brought it up again tapped some more. Flipped the barstock sideways to see if it all welded and it had all welded except the long piece of barstock that was on the anvil. I am guessing that I did not pre-heat the anvil enough? So now I got a piece of steel with eight layers but no handle so I am going to take it to my neighbors with the torch and weld a piece of rebar on the end of it for a handle to draw it out.
Whew! What a journey for a piece of steel that looks just like a solid piece of square key stock
Thanks for the help y'all gave me. Ya shoulda been there, it was like "the keystone cops try to forge damascus"!
Chuck
Chuck
