I've started use the bushcraft for various tasks, and it has worked perfectly so far. As noted earlier that 3V steel works just fine combining edge holding with excellent toughness.
I'm not done yet with testing, yet one of my first remarks is that the knife is quite thick.
AFAIK, the bushcraft is far tougher then a mora since it is substancially thicker and has a better steel.
Question is since mora in 1095 are generally tough enough already for "common" tasks, since CPM3V is supposed to be a zillion times better than average run of the mill steel, wouldn't simply shifting steel without substancially increasing thickness be enough to give it an above average toughness, or is it a particular problem about using 3V in thin pieces (so far, all the 3V knives I've since -and they aren't that common- are quite thick...).
