Thumb ramps galore!
Daniel Koster
www.kosterknives.com
More progress on the bushcraft knives today. Thank goodness for quality checkering files. :thumbup:
First, the spines are ground perpendicular. (waterjet cutting leaves a slight taper - you can see that the spines have a curved line on them...where the perpendicular part ends and the as-cut taper begins)
Next step is to take them to 400 grit to remove scratches (can't do this after the thumbramp has been put on). Then I spray the spine with Dykem marking fluid and scratch out where I want the thumbramp to start and finish.
Then it's cut, cut, cut....long, slow, laborious work. But simple! :thumbup:
Thanks for looking!
Dan
I love seeing them come together. It's almost as good as when you finally get it in the mail.
This may be a dumb question, but....
Could you bolt together a stack of blades and cut the thumb ramp with a mill or band saw? Maybe start the grooves this way and clean up with the file?
I'm not a machinist, but I play one on TV. :D
"Thanks for looking!"
No, thanks for sharing!!! :thumbup:
with a checkering file - definitely wears it out.
Thanks for the updates. You should offer some "skeleton" versions of this (just leave off the scales) as a neck knife. :thumbup:
Actually, I am offering "blade blanks only" for $45. :thumbup:
Dan,
Nice work. Blade blanks are great at that price, just as the knives themselves. Uh, is there gonna be a new list for those? If so, I'm definitely in for two.
Happy Thanksgiving all.
Jumping on this thread as I would also be interested in a blank, if they're heat treated.
Thanks,
Charlie
dang....I knew making this public would only add more orders....:foot:
It must be the Holiday spirit....Bring it on!! :thumbup:
Just add your name to the list, place an order with the Order Tracker and wait....:D :eek: :p
Here's what you'll get:
Blade will be fully heat-treated, ground and sharp!
Edges of the tang will be rough - since you'll have to grind it to put your own handle on it. If you want the tang edges finished out (ready to wrap it in paracord) add $5. :thumbup:
I'll post this info to the pre-order thread....one stipulation - I can't "swap" your current out for a blank blade. If you would like one, I'll gladly add one to the list. I think it will be best this way - for simplicity and for my sanity!
Thanks!
Dan
p.s. Happy Thanksgiving!
Dan can I change my order to reflect the bare blade (heat treated and razor sharp) with the tang ready for paracord? I would rather have my blade in this configuration than what I have ordered previously. Do I have to change it on the order tracker as well? Also, if this is an option, how about a kydex sheath for a neck or back carry (horizontal small of the back)? Let me know.
Jack
