Hi,
I have one of the first, it was an contract overrun for the Israelli army and uses mepro lights (just like trasers only flat).
You can see where you are going even in pitch darkness, it makes use of a prisma to see the degrees and to 'sight' and it's covered in a rubber-ish sleeve (green) that only leaves the top and bottom of the compass free. It is a little futuristic looking because of the form of the prisma and the rubber cover with "side extensions so you can grab the compass better.
It commes with an OD nylon pouch with fast release 'buckle'.
Mine has Jewish lettering on it.
There's no declination adjustment and no 'turning ring' to set course.
The disk inside turns smoothly and stops quickly the compass is oil? filled.
The compass is made by Plastimo, it says "Made in France" . Traser sells them for about 60 Pounds which is about $95
Traser specifications are:
Dual Function - Handbearing and traditional compass
Accuracy - 1 degree graduations
Optimum conditions to take bearings due to the wide 20% field of view
Temperature range of -20c - +60c
Ergonomic design
Smooth, non slip casing
Built in photoluminescent lighting
traser lights fitted for unbeatable night reading
No parallax error as a prism projects the reading of the bearing to infinity
Soft bottom cell prevents the formation of bubbles and leaks.
Easy to read due to the red lubber lines
Water proof to 50m
Weight - 105g
Diameter 83mm Height 33mm
5 year warranty
Please Note - This compass is not calibrated for use in the Southern Hemisphere
Size/Duration: 83mm_x_33mm
I love my simple plate compass by Silva (Brunton) better as it allows me to easilly set a course from a map.
I also use the the Brunton Eclipse, the deluxe version with "survival cards etc. and love that one also. Still the Traser works better at night without the need to have a Photon II between your teeth to be able to read the scale of the non illuminated compasses.
Best Scouting wishes from Holland,
Bagheera
