Practice, Practice, Practice
I've gotten one good side on one practice blade with a decent grind line. I've also played with a few finishing techniques. So now that I'm an expert
I'd like to try something else.
I'd like to have the ground portion (I'm using a flat grind) of the blade have a satin finish and the flats be brightly polished.
Here's a few of ideas:
1. bead blast the whole thing then redo the flats by hand sanding then polish on the side of a hard felt wheel.
2. use a scotch bright flap disk on the whole thing then polish the flats.
3. polish the flats then mask them off and use a scotch bright wheel on the rest.
BTW for the satin finish I don't really like the looks of hand sanding with 600 grit. I haven't tried a flap wheel but that sounds like it'd get the finish I want. I've also tried an 800 grit belt, but that creates a pattern. One other idea is to place a scotch bright pad on the palm sander. Might make for an interesting look.
Oh yeah has anyone tried non-woven belts?
Ideas?
Steve
PS My real steel is still on order, so some day I plan on making a real knife!
Ideas?
Steve
