Want to change my washers , which knid should I choice
Model is C42S viele , when it closed blade is not at the middle of handle . Beacause soft white plastic washers .
Altho it is very smooth , I want to change copper washers .
But don't know which kind to choice . give me some suggestion plaese .
HERE
Thank you very much .
Thank you , skcusloa .
I consider to contact spyderco , but get some problem
1st , C42 viele produce not anymore .
2ed , If I get the soft plastic washers as same as before , maybe when it closed blade is still not at the middle of handle . So I'm thinking about change copper washers .
3rd , I think all of spyderco knives is red or white plastic washers , not sure .I had C07S,C10pbk,C11pbk,C12GS,C36GPSBK,C41pbk,C42SC46P,C52p,C63GP,C68GP,C69GP2, C71,C85BLP , all of them is red or white plastic washers .
If the blade is not centered, and the knife is a liner lock, the problem is probably with the pivot and frame and not the washers. You can adjust it yourself or send it to spyderco. In general, spydercos washers will last the life of your knife and should never need repllacement.
