- Jan 9, 2014
Hello fellow makers! This is a quick fyi for you about split kydex eyelets.
I went to make a bunch of sheaths for our fillet knife yesterday and had a large number of eyelets split on me. As much as 80% of them! Usually we get the odd split eyelet but until now the norm has been less than 1%.
We just received a batch of 1000 black-coated brass eyelets (same type as we always use) from our supplier and it was these new ones that I was having the problem with. After a few I thought perhaps it was me (using to much pressure or something of that nature) but as I set a few more I began to realize it must be something else. I went on to check the flaring dies for damage or misalignment; everything checked out. That left the eyelets themselves.
Luckily we had 30 or so of the previous batch left to do some comparisons. I measured the length, inside diameter and outside diameter which all checked out as the same between the old and new eyelets. I tried to measure wall thickness but couldn't easily get a consistent reading. Then I weighed 14 each of the new and old eyelets on an accurate mini scale. I found the new eyelets to be at least 10% lighter than the old ones. This was very repeatable and consistent; I weighed a few sets of each type. Next I tried setting 10 each of the old and new. This last test confirmed my suspicion; 8/10 of the new eyelets split while none of the old ones did.
We called the supplier and they confirmed they are "aware of the problem" and are doing some testing. We found it a little disappointing that they wouldn't have sent out a notice or recalled them because there could be a lot of people out there using these defective rivets ( and pulling there hair out)!
Anyway, I thought I'd notify all of you in case you also start seeing a lot of split rivets. I intentionally haven't named the supplier as we are in the process of getting a replacement batch of rivets. PM if you want more details.
-mike
-mike
