What do you think of this for a freehand sharpening combo?
DMT stones in 220, 325
Hand American combo with 600 & 800 compound and textured/smooth leather plate (w/ CrO)
Ceramic 'steel' @ 1200 grit
Can I transition from the 325 diamond to the 600 loaded leather, or is the diamond too aggressive and I would need another step in grit? Speaking of aggressive, is the 220 overkill for reprofiling?
I had a 1200 ceramic before, I thought it was great for light touch ups, does the Hand American make a noticeable difference in edge performance on thin beveled blades? I usually like a toothy edge, but some of my blades aren't for abusive use, so I'd like to polish the edges just for shaving hair and other weird knut habits :D.
I think you have most of the bases covered there, but for my own tastes I'd put a fine DMT after the 325 DMT. That that would be a good step between the coarse stone and the strop. In fact, I like to put a black arkansas stone between the fine DMT and the CrO strop.
Most of the time, I just touch up on the black arkansas and then strop it a few times. This old fashioned combo is just pleasant to use.
I've never done any re-profiling, but I think you might want the 325 regular coarse DMT over the 220. Less chance of taking off too much too soon.
I have both 200/300 and 500/800 combo stones, alumina oxide($5-8 a stone), spydie ceramics(303mf double stuff), and a strop with veritas green(0.5 micron).
I can clear cut hair off my arms.:D
The DMT extra coarse is perfect for reprofiling. Significantly faster than the DMT coarse hone. I too think the 600 grit fine diamond would help.
Use will tell you where there are gaps to be filled, much depends on what you want and how you do it.
When I was a kid I used a single stone/grit, some fairly coarse, rough, small and cheap stones that I could find at the sunday market, we called them "navaja" stones, they did a fair job on the small pen knives we used at school to sharpen pencils but wore down very fast, almost like soap stone.
Later I started using an aluminum oxide hone that my father had (I still have it after over 40 years), that one served me well until a got a Washita/Hard Arkansas set from the U.S., I still use those quite a bit, later on I discovered Crock stiks, then one day I found an extra fine ceramic, my edges were getting sharper and smoother.
When I started surfing the internet I found out about diamond hones (I already had a small EZE-LAP, that was my "easy to carry for touch-ups" thing), and I got a ouple of DMT´s (medium and fine, or blue and red, whatever that is).
Then I discovered bladeforums, I have since gotten a much coarser stone and sandpaper from 600 to 1500 grits (I already had coarser), I have reprofiled some knives to much thinner edges, I feel I need an ultra fine ceramic and/or a translucent Arkansas, I have gotten some knives to pick off hair tips when drawn across the arm above the skin.
It´s getting too far, My name is Luis and I am a sharpoholic...
Sorry about the long post.
