What is hollow grinding?
So what is hollow grinding, and are there other types, and if so, what applications are there for each?
It's a REALLY basic question,I know, but a fellow needs to start somewhere.
First off ~ Welcome to the Forums. Don't worry about "basic" questions. . .we all had to start somewhere. Here is some info on "The Hollow Grind".
The hollow grind is done by taking two concave scoops out of the side of the blade.
Many production companies use this grind, because it's easier to design machines to do it. But many custom makers grind this way as well. Its great advantage is that the edge is extraordinarily thin, and thin edges slice better. The disadvantage is that the thinner the edge, the weaker it is. Hollow ground edges can chip or roll over in harder use. And the hollow ground edge can't penetrate too far for food-type chopping, because the edge gets non-linearly thicker as it nears the spine.
For designs where slicing is important, but the slice doesn't need to go too deep, this grind is an excellent choice. Many hunting knives are hollow ground, because field dressing is often best done with a knife that slices exceptionally well through soft tissues. Unfortunately, if you hit a bone, you can chip the edge, so the flat grind (see below) is also used often.
Another advantage of the hollow ground knife, at least at the beginning, is ease of sharpening. Most hollow grinds thicken slightly towards the edge. That means that as you sharpen (at least at first), the blade gets thinner and easier to sharpen.
After this, however, the blade begins thickening non-linearly and sharpening will become more difficult.
The ultimate push cutter, the straight razor, is usually hollow ground.
Check you e-mail. . . There is some more info there.
Livin' Life ~ Full Throttle
In hollow grinding, the blade is ground against an abrasive wheel, that creates "hollows" on each side of the blade. Whereas, a flat ground blade is usually ground against a flat platen, creating two flat sides. A convex ground knife is ground on a slack belt. Each style of grind has it's advantages and disadvantages. Hope this helps.
Bob Bizzell
