What steel holds the best edge?
Ok the more I research the more confused I get. In your opinion what steel (commonly avaliable in a folding knife) holds the best edge for general cutting chores?
Howdy and welcome to Bladeforums!
I think you asked two different questions, one in the title and one in the post.
The reason you are confused is that you are looking for a single answer. There is no single answer to this question.
Champ for ultimate edge holding among commonly available steels may arguably be ZDP-189, but that may not be the best for "general cutting chores". For my "general cutting chores", I need a combination of edge retension, toughness, and corrosion resistance. YMMV (Ease of sharpening is not a issue to me, it may be to you. )
There is no one best steel. Every steel is a combination of properties. Additionally, the heat treat is as important as the steel. So two makers can get different results out of the same steel.
For me, "general cutting chores" means cardboard, heavy plastic, trimming the occasional bush in the garden. This requires more than just slicing ability as many of these chores lead to consideral lateral force being applied to the blade. This leads to the combination of properties I mentioned above.
The commonly available folder steels that I find good for "general cutting chores" are
440A
420HC
AUS8
440C
AUS10
VG10
ATS-34 / 154CM
These are listed in vaguely increasing order of personal satisfaction with their performance, but I have knives in all of these steels that perform general cutting chores well for me. All of these assume a good heat treat. With 440A and 420HC it is especially important that you are aware of the maker's reputation, because there are so many blades that are poorly heat treated in these steels, so the steels get a bad rep when it should be the maker that is blamed.
