What the hell? Mag-lite Inside
I am a great Mag-Lite fan, but i've remarked something on the AA mini models
The lamp becomes all black after a period of using. Why? Why did not Mag Instruments do something about it? Because after a long time those flashlights don't illuminate as well as at the begining...
Brinkman sells a nexstar replacement bulb for their aa models that also fits the minimag AA - last longer & produces more light that the OEM bulbs. Take a look on candlepowerforums.com for more options w/ the minimag, including the Opalec LED retrofit.
Sam
thanks to whomever posted the candlepower address.I've been looking for a way to get the LED technolgy into my Mini-mag
Check out the Opalec NewBeam LED module for the Mini-Maglite. It takes less than three minutes to install and produces a bright white light for over 10 hours on a single set of batteries.
Check out this post on CandlePowerForums for more information on the NewBeam. It is one of my favorite products.
J.P.: I would like to point out that the upgrade kit for a maglite costs about $30, plus shipping. The "old" style Inova X5s can be had for around $30, and the brand-new ones with the new tailcap switch are around $40 or $50.
You do the math.
Plus, the Inovas are proven, whereas the upgrade kit is not.
Drjones
well i couldn't just read this thread and not comment. although the new innova's look like a very good product, they use expensive lithium batteries and are not regulated. this means while they start off about as bright as an arc ls, they get dim very quickly. teh opalec newbeam keeps an absolutely horizontal brightness curve over time (until the end) and has a tiny red led that lets you know when the batteries are depleted. it also uses common double a's. the innova does have a tactical switch on the back for momentary illumination and if you have lots of surefires it can be used to squeeze teh lasts out of the 123a batteries. so if consistent bright light is important to you you might be better off with the albeit more expensive newbeam. if you just want the cool factor of the x5 than you might be better off with it. you can find tons of threads on both of these lights using the search feature on cpf, so you might do some research. also, i think the blackening is caused by carbon molecules ending up on the inside of the glass, but i'm not sure about that. hope this has helped more than it has confused.
- Pete
Another thing to keep in mind with the Opalec vs. X5 is the cost to run the light. 2 AA's are far cheaper and more common then 2 123's. Best of all you can run Ni-MH’s in the Opalec and be just as bright as running alkaline or even lithium AA's. I did a runtime test last night on the Opalec using 2 GP 1800mA Ni-MH’s and it actually ran 8.5 hours before falling out of regulation, while using new Duracell’s it fell out of regulation just after 8 hours.
Don't get me wrong I really like the X5, actually I keep one in each of my cars, but they are almost to bright for close up task work. If you use the light a lot you can't beat the cost of using rechargeable in the Opalec.
Check out the runtimes I have tested so far
http://www.uwgb.edu/nevermab/battery.htm
