White penknife of the Die shell stanza line
Detail
Steel material.154-cm[the back of knife engrave a flower]
Protect a hand.303 stainless steels. [Engrave a flower processing]
Handle material.Red mat slice.Pearl shell[engrave a flower processing].The titanium nails.
All grow 17.5 cms.The blade grows 6.9 cms.Breadth 3.5 cms.
Sheath material. Leather[engrave a flower processing]
Main skill.Technique.
This knife.The part of blade first is use 8 inch sun round the machine sand bring to grind.
Then handicraft oil the stone Be thin to whet.Grind the line to each small machine.
All and by hand the work grinds into straight line.
The back of knife engraves a flower.This engraving a flower is by hand a work.
With the circle.Flat file slowly the Cuo pay wood grain.
Wood grain.It is also that the special design is stanza-like in shape.
Engrave a flower and manufacture before hot processing.
So the hot processing would manufacture a precision ago.
After the otherwise hot processing complete have no the way Cuo whet.
Protecting the hand is used 303 stainless steel manufactures.
Use 303 stainless steels to clip to fix by sandwich Mao.
The tight degree fixing is also the scope of request.
303 stainless steels particularly engrave lightning flash-like in shape cave slot
This engraving a flower is by hand a work.With circle file slowly the Cuo pay wood grain.
Special skill BE.
Usually handle with protect to hand over to connect overlap.It is pure to directly join.
But the modus of this knife is arc-like in shape.Of so want join.
Join together of have no blind side.BE need to slowly fix to whet at 1.1:00.
The precise sex request needed very high.
Handle material.Red mat slice.Pearl shell.The titanium nails.
The handle material is to use diameter more than 25 cms and super and big pearl shell manufacture.
And isn't each super and big pearl shells to manufacture.
While choosing a material if the surface contains Zhu hole or fracture.Is also have no a way manufacture.
And a slice of super and big pearl shell.BE not each either the parts can manufacture into a handle material.
Only take the thickest and the neatest.And grind to both sides neat back.
Still need to see whether the wrinkly fold assortment of pearl shell is good-looking or not.Whether there is fracture.
Each average super and big pearl shell can only take 1-2 slice handle material material.
The handle assistance used in material's fixedly nailing is the nail that the titanium makes.
Pearl shell's wanting to beat to nail to fix is a knowledge.
Drilling a hole first is certain.But the most difficult is to chase nail with the hammer
Beat into a speaker head.The pearl shell is a crumbly material so hammer
The strength control for hammering away is rather important.
Make an effort shell too much ground drop.The too light nail is easily loose.
The sheath material is to use 6 F leather stitch.
Alignment by disappearing inside the inside hair.
Want to stitch 6 F leather I still specially manufacture by myself.
The rhombus of lengthening cuts[beat to stitch hole].
The otherwise market-available rhombus cuts and can't wear deeply 6 F leather.
The skin engraves a flower.BE be stained with a wet skin first.Draw lines with a head pen.
As for why want to use 6 F leather to manufacture.
In order to protect this shell knife.
The hull of like chrysalis sort can protect knife well.
Beautiful little knife. A very eye pleasing well balanced combination of
filing on the blade, carved bolster and a m a z i n g pearl for the handle!
All the best,
David Darom (ddd)
VERY cool knife and great carving on the pearl.
The sheath suits it perfectly and adds to the overall package as well.
Pleasure to see it.
Peter
