I'll try to be a little more helpful than some previous posts.
First, how long have you had it? If it's relatively new, keep working it. Technique is everything, and it will "wear in," in a relatively short time. If you've had it awhile and it's not improved, it might benefit from a trip to customer service. That said.......
My 550 came last week. For the first two days, it was hard to open. Then two things happened, my technique improved, and the knife "wore in" to some degree. Which was greater, I can't tell you.
Smoothness of opening will improve, both for fast opening, and slow opening, over time, as your technique improves.
Watch this video: http://www.youtube.com/watch?v=ouMSEkI1rBo
Watch the fast opening technique. Use the top of the thumb nail, and flick rapidly upward, rather than pushing outward with the top of the thumb pad.
If your 550 is still slow to open, that's okay; a knife is a machine. Make sure you're not pushing in on the frame lock at the same time you try to push out on the blade. Then, open the knife slowly.
Like I said, mine took two days to loosen up and me to figure out the best way to deploy the blade quickly.
Once you've mastered the technique, and learned your knife, and it's worn in a little, you'll be very happy with your 550.
Hope that helps.
Thanks for the helpful post, hard to come by here it seems.
