ZT0300 Replacement Screws?
When I tried to switch the pocket clip from tip down to tip up, both screws stripped like they were made of warm butter. Any idea where I can get replacement screws, and how I can get these two stripped ones out of the knife?
Much thanks.
Kershaw will send you screws if you give them a model number. As far as removing stripped screws there are a number of methods.
If you dont know what you are doing dont make a bad situation worse let someone who knows how to do it fix it. Nothing pisses me off more than having to extract messed up bolts that someone kept trying to get out that didnt have a clue
If you can find one small enough, a left hand drill bit works wonders. Just don't take the threads with. And you also have to run the drill in reverse. :thumbup:
Did you use a torx wrench or an allen (hex) wrench. If your eyesight isn't real good it is hard to tell what the screw head is. Kershaw uses torx head screws.
The best tool to remove stripped screws is an easy-out.
send it in to ZT they will take out the old ones and put in the new ones, if you don't know what your doing, I have a stripped screw in a Brand new benchmade and I'm prolly gonna hafta send it in if i dont trade it off first.
