How do you sharpen a Kukhri?
There are several answers to this though it's not on topic. I'll mention them then move on. The easiest and best is a small belt sander (about $100 for the machine and all the belts). A ceramic rod does a fine job of touching up the edge, especially in the field. But the easiest answer of all is to simply ignore the area in the recurve at the rear of the edge. You don't use it for chopping anyway. A recurve is designed to give you the longest possible curved edge because that curvature increases the edge's penetration into whatever you're cutting or chopping.
I'd like to point out that the Blade Magazine Spring Special issue reviewed the N690Co Forester along with a number of other knives, evaluating them for a number of tasks and attributes including chopping. Admittedly, the other knives were a lot cheaper than the Forester and all of tool steel IIRC. Of a possible 5 points for each task the Forester scored all 5's except on one, Sharpening. All of the other blades scored 4 or less on everything. Forester scored a 0 on Sharpening - it didn't need to be resharpened after all the cutting and chopping it had done. If they had substituted Edge Retention for Sharpeing, the Forester would have scored 5 on that as well.
People make a lot of negative remarks about stainless steels and in some cases they should, but there is a tendancy to forget that the high carbide content in stainless steels, the very attribute that makes stainless steels hard to sharpen, are the same carbides that make the edge wear resistant.
Here's where stainless gets and sometimes deserves a bad rap. If you are heat treating a batch of 1000 stainless blades it is VERY difficult to get them all the same. The quenching rate can vary depending on where a blade is located when they purge the oven and hit it with cold air. There is a large thermal mass in 1000 blades and it can take awhile to draw off the heat and cool ALL the blades to where austenite (bad) is converted to martensite (good) - ~1000F. A blade that cools more slowly will have a higher level of retained austenite and thus be softer than blades that are quenched quickly. It will also have a coarser grain structure. So, if your blade is in the middle of the rack, it will take longer to cool than one that is nearer the cold air source and not completely surrounded by 999 other hot blades. How much variation is there? I don't know, but common sense argues there is some. I think that's why you often read of someone who has had lousy experience with a particular knife while others think it's great. When it was first introduced S30V was almost impossible for knife companies to heat treat correctly because it demands that Ms Start be achieved in under a minute or the steel will be soft and maybe brittle (I'm guessing on the brittle part, but that's the only explanation I can come up with for why some folks have seen brittleness in S30V, whereas others can demonstrate its inherent toughness). Knife companies eventually learned how to do it (I suspect it was smaller batches) and S30V blades made today are generally quite good. There are other parts of heat treating and knife/edge design that contribute to an edge being strong or weak, but the fault is not the steel. It's what is done to the steel that determines if it will perform well or not. N690Co performed better than I expected, and I'm pleased to have my name associated with it. The Cobalt seems to be doing it's job of detering cracks and that tiny bit of Vanadium does its job of refining the grain structure. Add to that the fact that Boehler doesn't put its name and reputation on the line with a steel that won't do the job for which it's intended.
So why does some N690Co not perform well? See above. Why the mixed reviews of S30V? See above. How does stainless steel make a knife blade that you can carry with confidence OR not? See above. You can't generalize about steels until you've tested it knowing that it has been correctly heat treated and the edge is specifically designed to match that steel to the application(s) intended for it. And on your end, don't baton a whittler through a piece of hickory.
