- Oct 11, 2014
I'm solving the problem of trying to use what I consider to be a great 21st-century pocketknife with a 2XL hand (I have fitted my own rifle's furniture, and worked refinishing cabinets). Considering G10 thickness and size I will be mostly doing carefully finessed sanding.
I am going to:
1) put a thumb stud ramp on the left panel of the BM940–1501;
2) notch along the opposite upper forward panel so my index finger will index;
3) increase traction using a Contego like pattern as a starting point;
4) I would also like to slightly reveal more of the jumping top and bottom like ApostleP did with his 710-D2.
5) swap out the stock clip with a black split arrow.
I've looked at all the attachments over at Dremel, and just got a refurbished 4200, waiting for accessory bits and some practice G10 in the same thickness and colors that I will cut down to a similar sized rectangle as the knife. I will be using a big old vice with scraps of ash to protect the knife. As a pattern I'm using calipers, and Gimp to resize and reduce image opacity of a Contego 1401 overlaid on my 940 (might have to false color one or the other at some point).
thoughts, suggestions, ideas?
			I am going to:
