Guys, it has nothing to do with blade length at all. It's how far the blade sits inside the handle, which is set by the stop pin. RYP has already stated what the fix is, and as long as that fix doesn't allow the lock to move all the way across the backside of the blade, it's a viable fix.
not true.
if the blade were 1/8" longer, and the point dropped a bit, it would sit nicely inside the scales.
I just measure and 1/8" longer and it would hit the back, but 1/16" longer would be perfect.
This will ring true if the knife is never used.
The edge(and tip) will recede every time the blade is sharpened.
A slightly longer blade will prove to be a temporary fix.
Amen brother, I'm with you..... :thumbup:You guys are looking at this all wrong! That little gap between the bade tip and scales is a "feature" that's perfect for cutting thread and dental floss and such without needing to open the blade..
